AutoSketch
New Member
davechad
Message 1 of 14 (3,897 Views)
Conversion of SKF files to DWG
3897 Views, 13 Replies
11-05-2009 04:50 PM
I am currently doing a bms graphics job but the floor plans i have aquired are in SKF format.
I am unable to open these files using any of the cad viewers I have.
Would it be at all possible for someone to convert these files to DWG so that i can open them using Trueview.
Dave C
*Richard Herman
Message 2 of 14 (3,898 Views)
Re: Conversion of SKF files to DWG
11-06-2009 02:55 PM in reply to: davechad
> Thanks
> Dave C
Hello Dave,
See attached. DWG2004. Conversion done with AS 9. After the conversion
it seems that 'layer 0' has become the current layer. You should
probably disable this layer as it is in the original .SKF files.
Best regards,
Richard Herman
New Member
davechad
Message 3 of 14 (3,898 Views)
11-07-2009 09:50 AM in reply to: davechad
Richard
Thanks very much for converting the SKF files for me
They opened in Trueview just fine and i have converted them into bitmaps after removing the non required layers.
Thanks again for your help.
Dave C
Member
sourabh.roy
Message 4 of 14 (3,567 Views)
07-12-2012 04:59 AM in reply to: davechad
I wanted to convert the attached .SKF files into readable Autocad format. Could you please help me with that.
Roy
New Member
bibonose
Message 5 of 14 (3,544 Views)
07-18-2012 09:09 PM in reply to: davechad
Hello all,
I sincerely wish if anyone could help me to convert 2 files from .skf to .dwg
many thanks!
PW
Member
sourabh.roy
Message 6 of 14 (3,538 Views)
07-19-2012 06:53 AM in reply to: davechad
Hi, I recently managed to resolve the issue which I was having with my .SKF files. You can open .SKF files in Autosketch. Once opened in Auto Sketch, you can save the file as .dwg format. Best Regards, Roy Roy Sourabh Junior Application Engineer Tel: +44 (0) 191 2135 555 | DDI: +44 (0) 191 2028 324 | sourabh.roy@symetri.co.uk | www.symetri.co.ukSymetri, Horsley House North, Regent Centre, Gosforth, Newcastle Upon Tyne, NE3 3TZ Symetri is an Astrium Service Disclaimer. The information contained in this e-mail and its attachments are confidential and intended only for the use of the named addressee(s). If you are not the intended addressee, please do not read, copy, use or disclose this message or its attachments. If you have received this message in error, please notify the sender immediately and delete or destroy all copies of this message and attachments in all media. Any views or opinions expressed are solely those of the author and do not necessarily represent those of Infoterra Ltd and shall not form part of any binding agreement. Infoterra Limited a company registered in England under number 2359955 and having its registered office at Atlas House, 41 Wembley Road, Leicester, LE3 1UT. VAT number GB 476 0468 27. P Before printing, think about the environment Infoterra Ltd. Is part of the Astrium GEO-Information Services Division and a wholly owned subsidiary of Astrium, Europe's leading space systems and services specialist. Disclaimer. The information contained in this e-mail and its attachments are confidential and intended only for the use of the named addressee(s). If you are not the intended addressee, please do not read, copy, use or disclose this message or its attachments. If you have received this message in error, please notify the sender immediately and delete or destroy all copies of this message and attachments in all media. Any views or opinions expressed are solely those of the author and do not necessarily represent those of Infoterra Ltd and shall not form part of any binding agreement. Infoterra Limited a company registered in England under number 2359955 and having its registered office at Atlas House, 41 Wembley Road, Leicester, LE3 1UT. VAT number GB 476 0468 27. Before printing, think about the environment
New Member
elizabethobaka8690
Message 7 of 14 (1,706 Views)
02-06-2014 07:11 AM in reply to: davechad
I also need help converting an skf file. could somebody help? We received an skf file from a client and it doesn't appear to come into CAD.
Thanks!
pendean
Message 8 of 14 (1,692 Views)
02-07-2014 04:55 AM in reply to: elizabethobaka8690
Go buy Autosketch 10 and bill it to the client: it's sold direct by Autodesk and through many retail outlets.
Does your client know you are publicly exposing their files like this? Most would get very upset :smileysad:
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Contributor
thixoman
Message 9 of 14 (1,276 Views)
03-25-2014 11:31 AM in reply to: davechad
Hi
hope these work for you !
Al Crosby
403 899 2237
crosby_a@hotmail.com
Active Contributor
thixoman
Message 10 of 14 (1,274 Views)
03-25-2014 11:38 AM in reply to: bibonose
here ya go !!
Al Crosby
