AutoSketch
Conversion of SKF files to DWG
19 REPLIES 19
Message 1 of 20
davechad
13751 Views, 19 Replies
I am currently doing a bms graphics job but the floor plans i have aquired are in SKF format.
I am unable to open these files using any of the cad viewers I have.
Would it be at all possible for someone to convert these files to DWG so that i can open them using Trueview.
Dave C
19 REPLIES 19
Message 2 of 20
in reply to: davechad
> Thanks
> Dave C
Hello Dave,
See attached. DWG2004. Conversion done with AS 9. After the conversion
it seems that 'layer 0' has become the current layer. You should
probably disable this layer as it is in the original .SKF files.
Best regards,
Richard Herman
Message 3 of 20
davechad
Richard
Thanks very much for converting the SKF files for me
They opened in Trueview just fine and i have converted them into bitmaps after removing the non required layers.
Thanks again for your help.
Dave C
Message 4 of 20
sourabh.roy
I wanted to convert the attached .SKF files into readable Autocad format. Could you please help me with that.
Roy
Message 5 of 20
bibonose
Hello all,
I sincerely wish if anyone could help me to convert 2 files from .skf to .dwg
many thanks!
PW
Message 6 of 20
sourabh.roy
Hi, I recently managed to resolve the issue which I was having with my .SKF files. You can open .SKF files in Autosketch. Once opened in Auto Sketch, you can save the file as .dwg format. Best Regards, Roy Roy Sourabh Junior Application Engineer Tel: +44 (0) 191 2135 555 | DDI: +44 (0) 191 2028 324 | sourabh.roy@symetri.co.uk | www.symetri.co.ukSymetri, Horsley House North, Regent Centre, Gosforth, Newcastle Upon Tyne, NE3 3TZ Symetri is an Astrium Service Disclaimer. The information contained in this e-mail and its attachments are confidential and intended only for the use of the named addressee(s). If you are not the intended addressee, please do not read, copy, use or disclose this message or its attachments. If you have received this message in error, please notify the sender immediately and delete or destroy all copies of this message and attachments in all media. Any views or opinions expressed are solely those of the author and do not necessarily represent those of Infoterra Ltd and shall not form part of any binding agreement. Infoterra Limited a company registered in England under number 2359955 and having its registered office at Atlas House, 41 Wembley Road, Leicester, LE3 1UT. VAT number GB 476 0468 27. P Before printing, think about the environment Infoterra Ltd. Is part of the Astrium GEO-Information Services Division and a wholly owned subsidiary of Astrium, Europe's leading space systems and services specialist. Disclaimer. The information contained in this e-mail and its attachments are confidential and intended only for the use of the named addressee(s). If you are not the intended addressee, please do not read, copy, use or disclose this message or its attachments. If you have received this message in error, please notify the sender immediately and delete or destroy all copies of this message and attachments in all media. Any views or opinions expressed are solely those of the author and do not necessarily represent those of Infoterra Ltd and shall not form part of any binding agreement. Infoterra Limited a company registered in England under number 2359955 and having its registered office at Atlas House, 41 Wembley Road, Leicester, LE3 1UT. VAT number GB 476 0468 27. Before printing, think about the environment
Message 7 of 20
I also need help converting an skf file. could somebody help? We received an skf file from a client and it doesn't appear to come into CAD.
Thanks!
Message 8 of 20
Go buy Autosketch 10 and bill it to the client: it's sold direct by Autodesk and through many retail outlets.
Does your client know you are publicly exposing their files like this? Most would get very upset 😞
Message 9 of 20
thixoman
Hi
hope these work for you !
Al Crosby
403 899 2237
crosby_a@hotmail.com
Message 10 of 20
thixoman
in reply to: bibonose
here ya go !!
Al Crosby
Message 11 of 20
thixoman
in reply to: sourabh.roy
here ya go
Al Crosby
Message 12 of 20
weeksygirl
Hello
Can anyone help me to convert the attached .skf to a .dwg or file that can be edited in Vectorworks 2014?
Clare
Message 13 of 20
thixoman
in reply to: weeksygirl
 send me your email an will send thru gmail account, , , file is large 174 MB zipped,  214 MB un zipped
Message 14 of 20
weeksygirl
in reply to: thixoman
Thanks!!, weeksygirl@yahoo.co.uk or weeksygirl@googlemail.com
Message 15 of 20
A.Terry
Hey everyone!
   Just found this post and im hoping someone can help me with this school assignment.
I need to convert this SKF. File to a DWG. FIle so I can read it in Autocad!
I'd really appreciate someone to take some time out of their day to help me out in this unfortunate situation.
If I had access to autosketch I would be able to do this myself but sadly I dont.
Thank you to anyone in advanced
Aaron Terry,
Hopeless Student.
Message 16 of 20
thixoman
in reply to: A.Terry
Hi
send me file crosby_a@hotmail.com an will git 'er done 4 ya !!!
Message 17 of 20
thixoman
Hi
if u having problems, msg me
Message 18 of 20
karl_heinz_moser
I would like to thank you for the quick help from Al Crosby. He has converted me to SKF files into DWG and PDF
Message 19 of 20
brent
Any way that someone could help me with converting a couple files to .dwg? They are .SKD files. Thanks you in advance.
Message 20 of 20
callumedge12
Hi Thixoman,
Can you please convert some drawings from SKF to DWG as i have no access to Autosketch and have been issued SKF drawings.
Any help appreciated!
Thank you
