Patrick
Do you ever choose commands off the menu? If you select line single from the
"Expert" menu and then choose Line Segment from the Menu (or from a short cut
key or custom menu) the Icon on the "Expert" menu fly-out will change to Line
Segment. If you click on the Line Single icon and get a Line Segment then that
is a bug, but I suspect the above scenario is more likely.
Rod
Patrick EMIN wrote:
> "John Nolte" a écrit dans le message de news:
> 548373AD1CB2CBA72A7EF6955540F3F2@in.WebX.maYIadrTaRb...
> > Patrick:
> > In AutoSketch terminology, lines and polylines are quite different. Lines
> > are single straight entities with a start point and endpoint. The Line
> icon
> > will only draw such entities. After drawing one line by specifying start
> > and end points, the next line alos needs both points defined and entered.
> > "Line multiple" will start the next line at the end point of the previous
> > one automatically. You will still have a series of single entities. You
> > cannot add a vertex to a line. If you Trim>Subdivide, AS converts it to a
> > polyline. Polylines can have intermediate vertices specified. They can
> also
> > have their width defined, which is very good for printing. There is also
> a
> > polyline segment icon. This inserts a polyline segment of the specific
> > width, length, and angle indicated on the edit bar.
> > You are learning a whole new dialect here compared to AutoCad.
> Thanks John for the clarifications, but my original question was really not
> about the type of objects you can create, but about a possible bug in using
> the "LINE SINGLE" icon.
> This particular icon, when used, sometimes (quite often actualy in my case),
> runs the "LINE SEGMENT" instead of the "LINE SINGLE" command.
> I was wondering if this behavior shows only on my system or if some other
> users have noticed it.
> (o)-(o)
> ---ooO---(_)---Ooo--------------------------
> Afitec France, http://www.afitec.com
> AutoCAD community http://communities.msn.com/AutoCADusersforum/
