One point about re-installing CAD software, Thomas. What I've said
previously (below) is pretty simple-minded and not the way computer
people would do it. It's just enough to get you going - maybe.
I'm certainly no expert here, but I know enough so that I would set up
the machine properly before doing any install from a CAD CD. This might
involve a preliminary THOROUGH (not Standard) scandisk and defrag,
rebooting with no programs loaded in the system tray AT ALL, maybe even
restoring an older registry prior to the defrag procedure if I suspect
some corruption there. You can also fix the registry easily enough
through Windows.
After going through all that, *then* I would install AutoSketch.
This probably isn't the forum for that kind of discussion, but I have a
few (actually MANY) moments at my disposal so I thought I'd pass it
along. If you want specific details (not too many because I don't *know*
too many) you can email me directly and we can go from there. If you
choose to email me, do it in English to prevent any mistranslation on my
part.
Ich hoffe, dass Sie verstehen.
That's the extent of 4 years of German language study 40 years ago. Not
bad, eh, Gerhard?
Was denken Sie? ok ok Was denkst du?
H
Harvey wrote:
> Thomas,
> What I can make out here: when AutoSketch attempts to open SKF files
> created after November, 2000, you get a message, "Unsupported CAD
> version, Error 412." SKF files created before that date open normally.
> Since you have an update I presume you have AutoSketch V6 with the patch
> installed. It could be that your version has become corrupted. What you
> can try is to uninstall AutoSketch through Windows, and reinstall it
> from the opriginal CD. If you do this, make sure you remove everything
> from the task bar and the system tray - INCLUDING any virus software
> before you install.
> And *don't forget* to reinstall the patch after you do this so that you
> have V6.01 complete.
> Otherwise I would have no idea why AutoSketch would open older files and
> NOT open newer ones. Especially if all the files were created with the
> same software!
> Meltdown wrote:
> > Hallo user's von Autosketch!
> > Ich hab folgendes Problem: Wenn ich versuche, *.skf Datein die nach
> > dem 01.11.2000 erstellt worden sind zu starten, bekomme ich jedesmal
> > ne Fehlermeldung, die wie lautet "Nicht unterstützte CAD-Version
> > Fehler 412". Aber alle Datein die vorm 01.11.2000 erstellt worden
> > sind, öffnet das Programm Autosketch inwandfrei und ohne irgendeine
> > Fehlermeldung.
> > Ich hab keine Ahnung warum Autosketch diese Fehlermeldung mir meldet,
> > obwohl die Datein ja ganz normale
> > Autosketch (*.skf) Datein sind.
> > Kennt jemand dieses Problem und wie kann ich dieses
> > beheben?? Ich hab's schon mit einem Update versucht, aber
> > leider negativ!!! Bitte, benötige dringend HILFE, denn diese
> > Datein muß ich in nächster Zeit neuberabeiten. PLEASE HELP
> > Mfg Thomas Koch
