AutoSketch
Autosketch symbols
8 REPLIES 8
Message 1 of 9
1887 Views, 8 Replies
Autosketch symbols
I have been trying to figure out how to import symbols into the library and retain the scale. i.e. 1/8"=1'. No matter what I do when I drop the symbol in the drawing it's huge, and doesn't keep the 1/8" scale I thought I created it in.
8 REPLIES 8
Message 2 of 9
Try: Change the scale on the symbol to what you
want and save it back to the library (over-write).
H
Message 3 of 9
I don't get it....!!!
I always thought drawings & symbols etc were drawn at a scale of 1:1 &
printing/plotting determined the scale. Perhaps I'm wrong but I could swear
I've read that before somewhere...!!!???
wrote in message news:5682662@discussion.autodesk.com...
created it in.
Message 4 of 9
You are correct, however to import them into a library you can choose to have them at a certain scale, and my problem is when I create the "icon" then change the scale to what I want, save it again as a .dwg at that scale, then import it to the library it doesn't keep it. When I open a new document to make my layout and change the scale to 1/8" and then bring in my newly created symbol. It doesn't stay at 1/8" like how I created-saved-imported, it goes to like 1"=50'. So I was wondering is there a step I am missing, or is it Autodesk doing whatever it wants to?
Message 5 of 9
wrote in message news:5683485@discussion.autodesk.com...
It's been my experience that regardless of what drawn scale a symbol is,
they're imported at the drawing scale. If the symbols were manually resized
previously, they will be at an incorrect scale.
Cheers,
John
Message 6 of 9
Maybe I wrong, but here's the understanding/method that has worked for me:
A symbol has a fixed inherent size. It doesn't have a scale, nor a fixed "on paper" size. "Scale" is a property of a DRAWING which affect the on-paper size of the symbol.
To change the size of a symbol and store it, I "explode" and then recombine it (so that AutoSketch no longer recognizes it as an existing symbol), stretch/compress it to the new inherent size that I want, and then save it as a new symbol with a new name.
Message 7 of 9
PS And that "scale factor" of an on-the-drawing symbol is just a size comparison of it to the symbol it came from.
Message 8 of 9
Thank you all for you suggestions. It worked resizing them to the correct size then importing them. However the blue handle it really really reallly far away from the piece/symbol. When I explode it the handle goes right on top of the symbol. How do I get the handle to stay next to the symbol and not so far away?
Message 9 of 9
Happy that it helped.
I think you're going to have to be a little more specific with your new question, maybe with a specific example.
But when I hear about a handle far from the selection, my first thought is that maybe you selected more than you thought you did. Easy to do in a right-to-left selection.
