Hello again
Found your problem, but it only happens when in the entity dialog.
We always adjust the negative factor from the Edit Bar by unticking the
Constrain box and put in the negative value. This also seems a lot quicker,
to me any way.
Paul.
"H. Alm" wrote in message
news:F767F4D7A57332C056975112BD692DE2@in.WebX.maYIadrTaRb...
> VERSION
> 6.0x, 7.0x, 8.0.23
> SYMPTOM
> It is perfectly possible to have a negative scaling factor on a symbol (in
> other words to mirror it around the x- or y-axis.)
> This can be achieved in many ways (using the mirror command OR selecting
the
> symbol and editing the scale factor in the edit bar OR mirror a symbol by
> selecting it and dragging the scaling handles OR ..)
> So, - to the point
> 1) Select a symbol with negative scaling
> factor
> 2) Use the menu command:
> Edit\Entities\symbol (or right click and select the appropriate command)
> X-scale and/or y-scale factor is
> negative in the dialog box
> 3) Click the OK-button
> 4) You will get an error message: "Value
> can't be less than zero (negative)"
> CAUSE
> Bad programming?
> WORKAROUND
> None
> All "tests" with
> - AutoSketch 8.0.23 and 6.01 using metric units (as opposed to
> imperial)
> - Windows XP
> H. Alm
