AutoSketch
Autosketch 2.1 replacement
4 REPLIES 4
markeporter
1120 Views, 4 Replies
I have a lot of files and macros created with Autosketch 2.1. I realise that the software is out of date, but have clung on to it until now. Has anyone any recommendation of what to replace it with? From what I can discover about Autosketch 10, it does not include a macro capability. The ability to create macros is very important to me. My budget is $300.
regards
Mark
4 REPLIES 4
StevenMac
in reply to: markeporter
Mark excuse my ignorance, but what is it you do with your macros?
markeporter
I have some generic panel designs for making articles from fabrics. They are driven by parameters. In Autosketch 2.1 it's easy for me to make a generic pattern macro, with parameters in another, simpler, macro that calls the main macro. I don't mind changing my process, but I'd still like to capture the geometric rules in a file and drive each specific design with parameters.
You are correct in discovering AutoSketch 10 doesn't create/import macros.
For a $300 budget, investigate the free AutoCAD LT clones available via a
Google search. Although LT can create macros, expect a very steep learning
curve.
There is nothing else out there...certainly not in the AutoDesk stable.
Ric Norris.
wrote in message news:6286820@discussion.autodesk.com...
regards
Mark
StevenMac
Mark that sounds cool.
I think your best bet will be to ask for that as a feature in Sketch's replacement.
http://discussion.autodesk.com/forums/forum.jspa?forumID=399&start=0
