My autosketch program is not allowing me to view everything that I need to view in pop up windows. I have attached a picture of what the issue is. The "drawing options" window is cutting off the right half of what should be presented in the window
This will be hard to troubleshoot because this program is not tested under Windows 7.
http://forums.autodesk.com/t5/AutoSketch/Autosketch-10/td-p/2746635
I have 2 suggestions:
1. Run it in compatiblity mode. It is similar to step 4 here:
http://upandready.typepad.com/up_and_ready/2013/07/unsupported-autocad-2014-on-windows-vista.html
2. Run it in Windows XP Mode. If the UI looks good, then use it in XP mode.
http://windows.microsoft.com/en-us/windows7/products/features/windows-xp-mode
