Dear Confused
Every version of Drafix and AutoSketch opened DWG and DXF files in different
ways, one even keeps AutoCAD dimension entities in one piece sometimes, but
then I am not telling you anything you do not already know.
However, even as developers we have a copy of every version of these
programs on our computers just in case one does not to a transfer properly,
then we move down to the next. Drafix 4.1 and 6.01 seem to do the best and
even V6 to V7 treat files with XREF differently.
The problem could be blamed on Sketch but deep down Sketch is trying to open
formats that change the rules all too frequently. Apart from that every
other software manufacturer seem to have their own versions of DWG and DXF
files so I see multiple copies of Sketch on a computer as a fact of life.
Also, we have copies of LT and ACAD and often Sketch may do a better job of
opening a file than LT, so where's the justice in that?
Also Confused.
"Barry Higginbottom" wrote in message
news:E2ED8B6ABCDE032DAEB813A8424A956C@in.WebX.maYIadrTaRb...
> Well, I've only got to eat half a humble pie!
> Mapping shx to true type might work with R14 dwg files but it don't work
> with R14 dxfs.
> Trying to import the same drawing but this time using its DXF format comes
> up with a dialog
> "Open Shape File"
> The file name box is prompting for te______.pfb with a file type of .shx
> Huh?
> The only way out is to hit the Cancel Button which then gets me into a
loop
> of selecting SHX files until I guess the right one (in this case TXT)
> So, Mr AutoDesk what's a te______.pfb file when its at home?
> And where do I get one from?
> Barry (Confused)
> news:DD420598C9D16A38C471A7CB939D4950@in.WebX.maYIadrTaRb...
> > Harvey
> > > When you consider that an R7 skf file can't be read by R6, you
shouldn't
> > > be too surprised, Barry.
> > I know, I know, but the thing is I've got to eat humble pie now, 'cos
I've
> > figured out how to get it to work!
> > Why, oh why wasn't it mentioned in the readme file (and I have checked)
> that
> > there is now yet another option on dwg file import to map shx files to
> true
> > type.
> > I ask myself, if it wasn't needed before why is it needed now, must be
> just
> > another way to catch folks out!
> > Ah well, after nearly 20 years of using computer software you think I'd
> know
> > by now to RTFM!
> > At least I would if I had one, only comes as a PDF with the AS8 upgrade.
> > BTW AS7 can read AS8 files, is this progress?
> > Tara for now.
> > Barry
