AutoSketch
All Line Lengths Doubled in Length
3 REPLIES 3
baumgrenze
2188 Views, 3 Replies
I just opened a sketch I used a few weeks ago to fit furnishings into the living room. Today when I check a line length with the horizontal dimension tool I find that the length is twice what I intended and I think I used last time.
Is there some simple tool I may have invoked that kept my scale at 1:100 but somehow doubled all of the dimensions?
If so, I gather it should be possible to reverse the process and halve them again.
Thanks in advance,
baumgrenze
3 REPLIES 3
baumgrenze
in reply to: baumgrenze
I think I may have found my answer. Am I correct? I believe the command is Edit>Transform>Scale. It seems to change the scale of the selected objects without changing the scale set under Tools>Drawing Options>Scale.
I must have inadvertently invoked the former command at some point.
Thanks again,
baumgrenze
Fred9002
Yes, that's exactly what that tool does.
Sincerley,
Fred
baumgrenze
in reply to: Fred9002
Thank you Fred for the confirmation!
