Kevin,
just for giggles, if you have continued problems, REMOVE your printers to see
what happens. Sketch does "ping" for lack of a better word your printer when it
starts. If it does not like your printer for whatever reason, It will not load
correctly !
I too have wrestled with AS7 as many others have. It works best on a computer
that you will NOT be adding a million other apps to. But when it works, it is an
excellent little program.
I sure wish...... well, most of you KNOW what I wish !
keep us posted,
Chris L
"Kevin B." wrote:
> Hello Chris,
> I did everything you suggested and SO FAR SO GOOD! But I'm not going to say
> problem solved just yet.
> FYI: First, I did not remove earlier version of Sketch, which could have
> been the problem. ( I Should have known better).
> To answer your questions: I did just install an HP1220Cse Printer, however I
> believe these error messages arrived before printer. No strange MS errors.
> I have had more problems with AutoDesk and Adobe programs than any other
> software I have ever used!
> Thanks a million for your help. I will keep you updated if anything strange
> happens.
> Kevin B.
> "Chris L" wrote in message
> news:3C43BB33.360F070@lakefield.net...
> > Shutdown, restart, control panel, add/remove programs, remove Sketch,
> rename
> > what ever is left of sketch in Explorer to OLDsketch, shutdown, restart,
> > Ctrl-Alt-Del, close any and all uneccessary programs, make sure no
> anti-virus
> > proggies are active, Reinstall Sketch, try program.
> > If it runs, restore your toolbars and settings. Ditch the old leftovers
> when
> > no longer needed. If it does not run, Go out and buy V8 and see if it is
> > better, then report back to us !
> > Did this just start to do this ? Any recently installed programs?
> > Any changes in the MS crazy stuff like "make every program on my computer
> look
> > like a web page"? Any hardware changes ?
> > If you just had one error, I'd blame your Video Card. That's what we
> learned
> > to do when Sketch does not work.
> > waiting for your reply,
> > Chris L
> > "Kevin B." wrote:
> > > Where do I start,
> > > I'm just going to list errors, too much to explain when I get them.
> > > fault in KERNE32.DLL closing program, blah,blah, restart windows
> > > fault in ACGE15.DLL closing program, blah,blah, restart windows.
> > > Floating point error 8x20? this happened several times with different
> sets
> > > of numbers.
> > > Fatal error try to recover or shut down ( I've shortened this).
> > > I think that's all????
> > > Using V7 0n WinME
> > > Thanks!
> > > Kevin
