Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
unhandled exception
1 REPLY 1
j.vanderheijden
263 Views, 1 Reply
unhandled exception
When i place my first panel with ilogic and i change one measure in the 'Place ilogic Component' view i get an error.
Then i click continue and i can change the second measure and again a get the same error.
After changed both measures nothing happens.
The panel will not be placed.
When i don't change anny measure the panel will be placed.
Mvg Jos
Your drawings are only as good as the symbols that complete them...
1 REPLY 1
Hi Jos,
I didn't get any error when I palce the part with iLogic by Place iLogic Component command and change the measure.So can you help attach the video of your workflow.
-Xuesong
Please mark as a solution if somehow I got it right.
