You guys need to fix the TRIAL download link for autodesk Factory 2013, it's actually Autodesk Infrastructure Design Suite 2013.
johnlabs,
Can you please try the link again? It should be fixed now.
Thank you.
-Ted Saufley
Ok its the right link now, but it's asking for a forth part, I have only got 3 file, the download say it's three part only. So I cannot extract it. It's saying next volume is required (Autodesk_FDSADV_2013_English_Win_64bit.part04.rar).
4.part file is missing! I didn't install. Could you take link to only 4. part file ?
This should now be corrected. Please let us know if you run into more problems.
Sorry for the inconvenience.
Jeff
The trial page now has the FDS files: http://usa.autodesk.com/adsk/servlet/download/item?siteID=123112&id=16673550
Everything seem ok, Download is four parts, and extract fine, Install went ok. I have to try it now.
Happy to hear that the download is working properly now. Please let us know if you experience any other issues.
Thanks.
-Ted
The part 4 for the 32 bit trial version is missing. Could you please post the link for the 4 part?
Thank you.
Daniel
Hi all -
We think that this got fixed earlier today. Could you try again, and see if you get the right pieces?
Thanks for your interest!
Jeff
My install froze somewhere in the middle of the installation, and now I can't uninstall any of the programs through Programs and Features or the Unistall Tool (it wasn't installed). This also means I can't start the install process again, because it thinks the products are already installed.
Can you provide the Uninstall Tool for FDS or someway to remove the failed suite?
Hello pistonrod8,
Here is a link to a very useful Microsoft utility called Fixit that may solve your problem.
http://support.microsoft.com/mats/Program_Install_and_Uninstall/
I've used it several times with great success. Hope it works equally well for you.
Best regards,
-Ted
