Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
The workaround for low performance when opening JT files in Navisworks
0 REPLIES 0
Message 1 of 1
XuesongBai
363 Views, 0 Replies
Dear FDS users, If you encounter the issue that is low performance when opening JT files (especially later 8.0/8.1 version)in Navisworks. Here are the workaround for your reference. Step 1: Open JT in Inventor, with these following critical options checked (snapshots attached) -Turn off "Solids","Surface" and "Wires" Entity type to Import area -Tessellation Detail: set to “Lowest Detail” – this eliminates excessive facet data retrieval -Data Organization: set to “Import Assembly as Single Part” – This gets around the sloow inventor assembly file save. Step 2: Save the ipt file Step 3: Load the saved ipt to Navisworks. Thanks, -Xuesong
Please mark as a solution if somehow I got it right.
0 REPLIES 0
