Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
sheet metal style
2 REPLIES 2
j.vanderheijden
337 Views, 2 Replies
sheet metal style
I thought I knew but there is something else.
I have various styles created my behalf sheet metal panels.
Now I want from the base all four sides separate places because we want to be flexible in each side separately adjust the height.
The corners are in a certain way to each other and is dependent on the supplier there for the various styles.
When I made my panel and I change of style I had hoped that the corners would also change, but that does not happen.
If I place the four sides in the same command then the corners change after changing the style.
Now I can do a Corner Seam, but when I change the style, the corners not change.
Am I missing something or is this the manner of Inventor?
I attach two parts where the different corners in.
I want to switch between the two styles(corners) in one part.
Mvg Jos
Your drawings are only as good as the symbols that complete them...
2 REPLIES 2
S_May
in reply to: j.vanderheijden
Hi @j.vanderheijden
Are you talking about the FDU or is the problem a sheet metal problem?
S_May
in reply to: S_May
Hallo @j.vanderheijden
the style of the tab can be changed, the style of the corners must be changed separately
