Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Rendering troubles
3 REPLIES 3
Logos_Atum
592 Views, 3 Replies
Rendering troubles
Hello there,
we have had some troubles rendering a large Factory Layout. As we need it to be 10811 by 10811 pixels in size
we ran into the 10000 by 10000 render limit in the first place. Ok that´s not that crucial I guess. some dpi will be
missing, but it should not be noticed. Sadly Inventor crashes every time we start to render, I´ve sent the error report.
I tried to upload the assembly to Autodesk 360 and got no message at all... could not take days I guess, so that´s
the second problem I encountered. Importing to Showcase failed due to a RAM issue, 24 GB were´nt enough. I´ve
expanded the system RAM to 32 GB. It might work now, but I did not test it yet. I would have used the FBX export from showcase for MAX if showcase itself would have refused to render a image that large.
Via a 3rd party plugin I exported the assembly as an FBX, which I am currently importing to MAX Design. I hope this works. Also it would be nice because I could assign the job to 5 machines for rendering.
Are there recommendations for rendering print quality graphics? Which program to use, file sizes corresponding to
hardware limitations? It took way to long to play with all the settings and I have a deadline to meet.
Is anyone offering services for rendering large files?
Glad for any input
Kind regards
Daniel
Dogs aren´t flammable.
3 REPLIES 3
DarrenP
in reply to: Logos_Atum
with 3ds max you can setup a render farm to render a large print
DarrenP
Logos_Atum
Hello there,
renderfarm has been set up and is waiting for the call 😉
I will make use of 5 machines. Each of them running a
4core 8 thread Xeon. The Host system is equipped with
32 GB of ram, the clients are equipped with 16 GB each.
All I need to do is to import a 380 MB FBX and feed it to
Backburner.
I will compare it to the Showcase image which is currently
rendered. I hope it´s as fine as expected. I will give you a
short notice.
Kind regards
Daniel
Logos_Atum
Hello there,
I had to render in Showcase. Max crashed when I changed the pixel dimensions ^^.
Smaller files rendered as expected. I think I need a lot more practice and a vacation 😉
Kind regards
Daniel
