Autodesk Factory Design Suite General Discussion
j.vanderheijden
Message 1 of 10 (416 Views)
publish targets
416 Views, 9 Replies
01-04-2012 01:10 PM
Under Publish Target i can ad new folders to put in the assets.
What if i want to do the same by an other computer, can i copy something or do i have to do it all over again.
Mvg Jos
Your drawings are only as good as the symbols that complete them...
Yes, you could directly publish to a folder on the server. Please invoke Inventor Projects dialog and set project library which mapped to a shared folder on the server. After that, you could see the shared foler in Publish Asset dialog.
Sucy
Hi Jos,
It can not be set directly in the FDS option. As Sucy's snapshot, it need to be set in the Invetor project.Afterwards, if you want to use the asset which is shared at server in AutoCAD Architecture/Mechanical, you need to select the active Inventor project in Options>-Factory Assers tab >-Libraries in AutoCAD Architecture/Mechanical. Please refer to the snapshot.
-Xuesong
Employee
XuesongBai
Message 2 of 10 (413 Views)
Re: publish targets
01-04-2012 05:42 PM in reply to: j.vanderheijden
Not exactly, you can copy the all of folder including published assets to other computer or you can publish the asset to the shared folder which should be set as Library in Inventor>-Projects Editor>-Library node.
thanks,
-Xuesong
j.vanderheijden
Message 3 of 10 (382 Views)
Re: publish targets
10-04-2012 02:51 AM in reply to: XuesongBai
Can i directly publish to a folder on the server.
How do i publish to a shared folder.
Can i change the pad of the folder in the FDS options?
I can't find an option to change te pad to the folder i placed on the server.
Mvg Jos
Employee
guosu
Message 4 of 10 (361 Views)
Re: publish targets
10-09-2012 08:01 PM in reply to: j.vanderheijden
Sucy
Employee
XuesongBai
Message 5 of 10 (352 Views)
Re: publish targets
10-09-2012 11:02 PM in reply to: j.vanderheijden
Hi Jos,
-Xuesong
j.vanderheijden
Message 6 of 10 (342 Views)
Re: publish targets
10-10-2012 12:42 AM in reply to: XuesongBai
Xuesong
Your option is when i want to use the assets in autocad/mechanical?
But i want to share a folder so everyone can use the assets in Inventor.
Would your option also fore use the assets in Inventor?
Mvg Jos
Employee
XuesongBai
Message 7 of 10 (335 Views)
Re: publish targets
10-10-2012 01:10 AM in reply to: j.vanderheijden
Jos,
My setting continue the comments by Sucy.Sure, it is for ACA/ACM. For Inventor, you need to set the shared folder path in Inventor project editor. Please refer to Sucy's snapshot.Set Project Library.png
-Xuesong
j.vanderheijden
Message 8 of 10 (330 Views)
Re: publish targets
10-10-2012 02:17 AM in reply to: XuesongBai
Thanks, it works.
Mvg Jos
j.vanderheijden
Message 9 of 10 (164 Views)
Re: publish targets
04-30-2014 02:10 AM in reply to: j.vanderheijden
When i am in Acad Architecture i can't see the folder in the asset browser.
I did all the settings and still can't see the folder.
I made the setting in Inventor Project to map the library to a folder on the server.
In Acad Archtecture in the options, Factory Assets, i browsed to the folder with the .ipj.
Do i mis something?
Mvg Jos
Employee
XuesongBai
Message 10 of 10 (144 Views)
Re: publish targets
05-02-2014 04:56 PM in reply to: j.vanderheijden
Have you refreshed the asset browser after setting all?
-Xuesong
