Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Problems with dimensions changing
1 REPLY 1
Light_Guy
260 Views, 1 Reply
We have recently upgraded to the FDS product line and have just begun creating our asset library. While creating an assembly that will become an asset I have hit a brick wall. As soon as I create an iLogic rule or try to constrain a part, the dimensions of the part I am picking magically get changed to 0 and I wind up with a profile loop error. This has become very frustrating as I cannot create even a simple assembly.
Paul Hamor
"Always good ships!"
1 REPLY 1
Logos_Atum
in reply to: Light_Guy
Hello there,
did you create the parameters controlling the ipt´s in the assembly with an initial value assigned?
If not- this is likely to happen.
Avoid this by employing the following workflow.
  1. Open the assembly in the asset builder
  2. Create all the parameters for the ipt´s on the assembly level and assign them as key
  3. Link the *.ipt parameters to the assembly
You should be encountering no problems that way
Kind regards
Daniel
Dogs aren´t flammable.
