We have recently upgraded to the FDS product line and have just begun creating our asset library. While creating an assembly that will become an asset I have hit a brick wall. As soon as I create an iLogic rule or try to constrain a part, the dimensions of the part I am picking magically get changed to 0 and I wind up with a profile loop error. This has become very frustrating as I cannot create even a simple assembly.
Hello there,
did you create the parameters controlling the ipt´s in the assembly with an initial value assigned?
If not- this is likely to happen.
Avoid this by employing the following workflow.
1. Open the assembly in the asset builder
2. Create all the parameters for the ipt´s on the assembly level and assign them as key
3. Link the *.ipt parameters to the assembly
You should be encountering no problems that way
Kind regards
Daniel
