All,
I haven't used the syncing functionality in a little while, but am having trouble getting it to work. In the past, I would have created a partial layout in AutoCAD, sync to Inventor and then make whatever changes necessary. Then I would sync my layout back to AutoCAD, but that no longer seems to be working. Have tried to sync a couple of different test layouts and have gotten the attached error message. Does anyone have any thoughts? Thanks in advance for any assistance and have a most blessed day!
Peace,
Pete
Hello there,
did you check if there already is a link to a DWG file in Inventor?
If so remove the link reference and it might work.
Apart from that I must admit I got that message too already and
was not able to solve it every time.
Kind regards
Daniel
Daniel,
I am not sure if you have noticed the same thing, but this only really seems to happen when I have custom asset chains, the ones that I created from scratch. Have never experienced this kind of trouble with custom or stock assets, only these custom chains... I will try to monkey with the link file and see if I can make any headway there, but just wanted to see if you had made the same observations. Hope all is well and have a most blessed day!
Peace,
Pete
Can someone from Autodesk take a look at this thread? I am not sure what else to try and this really only seems to be happening when I use custom asset chains. Perhaps there is something with that modeling process that I am not doing correctly...
Peace,
Pete
Xuesong,
No worries, I unmarked the solution. Here is the chain asset and the two segments I used to make the chain. If you have any questions, please do not hesitate to contact me. Hope all is well and have a most blessed day!
Peace,
Pete
