Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
partnumber in text on part
10 REPLIES 10
Message 1 of 11
702 Views, 10 Replies
I have made a part  with iLogic so the part number comes on the part with text.
If I sync the part now  with acad  the text is not visible.
Is there a possibility that the text will be visible?
Perhaps I have to place text in a different way.
10 REPLIES 10
Message 2 of 11
XuesongBai
Hi Jos,
Why not create a feature based on the text? I create Emboss feature based on Text sketch, so that the text will be projected on the 2d DWG and then  visible in ACAD?
-Xuesong
Please mark as a solution if somehow I got it right.
Message 3 of 11
in reply to: XuesongBai
Hi Xuesong.
i didn't no that you have to create a feature to make the text visible.
Thanks, it works great.
Message 4 of 11
Is it possible to fill in the numbers with collor so they don't have an open structure?
Message 5 of 11
XuesongBai
Hi Jos,
I didn't understand what you mean. Do you mean show the color of the text in Invnetor?
-Xuesong
Message 6 of 11
Look for the picture, i want it as the text on the top.
Message 7 of 11
XuesongBai
Hi Jos,
I understand you.
Unfortunately,it is the limitation of Inventor. The contour of the feature will be only projected.
-Xuesong
Message 8 of 11
As in the picture i sync the part to acad and placed the text in acad.
Would it be possible to link the text in acad to the emboss text?
Then in inventor make the emboss text invissible and only see the acad text.
Maybe with some ilogic!!
Message 9 of 11
XuesongBai
Hi Jos,
I have an idea. we can export the number to excel by iLogic in Inventor. And then link the excel data in ACAD by Insert table function. So any data change will be updated in Excel and afterwards updated in ACAD.
The attached is the result. There is border around the number, but I don't know how to clear it.
Message 10 of 11
I will try.
That ilogic code is that standard  in ilogic with a standard snippet?
Can you give me a hint.Smiley Wink
Message 11 of 11
XuesongBai
Hi Jos,
Maybe we should use the csv file.  So the iLogic is in my snippet.
Good luck.
-Xuesong
