Autodesk Factory Design Suite General Discussion
j.vanderheijden
Message 1 of 11 (223 Views)
partnumber in text on part
223 Views, 10 Replies
08-20-2012 02:08 AM
I have made a part  with iLogic so the part number comes on the part with text.
If I sync the part now  with acad  the text is not visible.
Is there a possibility that the text will be visible?
Perhaps I have to place text in a different way.
Mvg Jos
Your drawings are only as good as the symbols that complete them...
Employee
XuesongBai
Message 2 of 11 (222 Views)
Re: partnumber in text on part
08-20-2012 02:38 AM in reply to: j.vanderheijden
Hi Jos,
Why not create a feature based on the text? I create Emboss feature based on Text sketch, so that the text will be projected on the 2d DWG and then  visible in ACAD?
-Xuesong
j.vanderheijden
Message 3 of 11 (220 Views)
08-20-2012 03:11 AM in reply to: XuesongBai
Hi Xuesong.
i didn't no that you have to create a feature to make the text visible.
Thanks, it works great.
Mvg Jos
j.vanderheijden
Message 4 of 11 (216 Views)
08-20-2012 03:20 AM in reply to: XuesongBai
Is it possible to fill in the numbers with collor so they don't have an open structure?
Mvg Jos
Employee
XuesongBai
Message 5 of 11 (204 Views)
08-21-2012 12:30 AM in reply to: j.vanderheijden
Hi Jos,
I didn't understand what you mean. Do you mean show the color of the text in Invnetor?
-Xuesong
j.vanderheijden
Message 6 of 11 (203 Views)
08-21-2012 12:44 AM in reply to: j.vanderheijden
Look for the picture, i want it as the text on the top.
Mvg Jos
Employee
XuesongBai
Message 7 of 11 (197 Views)
08-21-2012 01:28 AM in reply to: j.vanderheijden
Hi Jos,
I understand you.
Unfortunately,it is the limitation of Inventor. The contour of the feature will be only projected.
-Xuesong
j.vanderheijden
Message 8 of 11 (193 Views)
08-21-2012 01:50 AM in reply to: XuesongBai
As in the picture i sync the part to acad and placed the text in acad.
Would it be possible to link the text in acad to the emboss text?
Then in inventor make the emboss text invissible and only see the acad text.
Maybe with some ilogic!!
Mvg Jos
Employee
XuesongBai
Message 9 of 11 (193 Views)
08-21-2012 02:41 AM in reply to: j.vanderheijden
Hi Jos,
I have an idea. we can export the number to excel by iLogic in Inventor. And then link the excel data in ACAD by Insert table function. So any data change will be updated in Excel and afterwards updated in ACAD.
The attached is the result. There is border around the number, but I don't know how to clear it.
j.vanderheijden
Message 10 of 11 (189 Views)
08-21-2012 02:48 AM in reply to: XuesongBai
I will try.
That ilogic code is that standard  in ilogic with a standard snippet?
Can you give me a hint.:smileywink:
Mvg Jos
