I have made a part with iLogic so the part number comes on the part with text.
If I sync the part now with acad the text is not visible.
Is there a possibility that the text will be visible?
Perhaps I have to place text in a different way.
Solved by XuesongBai. Go to Solution.
Hi Jos,
Why not create a feature based on the text? I create Emboss feature based on Text sketch, so that the text will be projected on the 2d DWG and then visible in ACAD?
-Xuesong
Hi Xuesong.
i didn't no that you have to create a feature to make the text visible.
Thanks, it works great.
Is it possible to fill in the numbers with collor so they don't have an open structure?
Hi Jos,
I didn't understand what you mean. Do you mean show the color of the text in Invnetor?
-Xuesong
Hi Jos,
I understand you.
Unfortunately,it is the limitation of Inventor. The contour of the feature will be only projected.
-Xuesong
As in the picture i sync the part to acad and placed the text in acad.
Would it be possible to link the text in acad to the emboss text?
Then in inventor make the emboss text invissible and only see the acad text.
Maybe with some ilogic!!
Hi Jos,
I have an idea. we can export the number to excel by iLogic in Inventor. And then link the excel data in ACAD by Insert table function. So any data change will be updated in Excel and afterwards updated in ACAD.
The attached is the result. There is border around the number, but I don't know how to clear it.
I will try.
That ilogic code is that standard in ilogic with a standard snippet?
Can you give me a hint.
Hi Jos,
Maybe we should use the csv file. So the iLogic is in my snippet.
Good luck.
-Xuesong
