it seems there is a problem with the Navisworks 2015 SP1 that effects the Factory Design Utilities for Navisworks
this is the error i get after sucessful installation of the service pack 1 and then launching Navisworks Manage 2015 from the Factory Suite this happens with or without the Autodesk Factory Design Utilities 2015 Update Pack 1 installed
you can hit ignore and Navisworks does open but you do lose the Factory tab in the Ribbon the only fix was to uninstall the service pack
can anyone else confirm this?
i have tried this on 2 machines
1 with Win 7 and 1 with Win 8 both 64 bit
DarrenP
Solved by DarrenP. Go to Solution.
on the Win 8 machine
this error comes up first before the one above after installation of SP 1
DarrenP
We are aware of the issue and are working on a hotfix. Please remove Navisworks SP1 for now if you want to use the Factory utility.
thats what i did
DarrenP
this has been fixed
DarrenP
