Autodesk Factory Design Suite General Discussion
j.vanderheijden
Message 1 of 4 (79 Views)
Link parameters in iMate
79 Views, 3 Replies
12-03-2012 06:49 AM
I have two parts made of Sheet Metal.
In the sketch of the Face I made an offset and linked to a parameter.
The intention is that I want to use the offset in a iMate to the thickness of the paint line to be determined.
I want my parts placed with the netto size and the imates use the lakdikte to give as yet on the total size to get.
I have the parameters associated with excel.
For the panel I have two parameters linked in a new parameter and placed the parameter in the offset of the iMate.
When I place the bandraster and then the panel i can not use that imates.
If I have a single parameter in the iMate , so no associated parameter, then it works well only I have the lakdikte of the two parts are not connected and I have to retrofit.
Why can't I place a associated parameter in an iMate ?
Mvg Jos
Your drawings are only as good as the symbols that complete them...
Employee
XuesongBai
Message 2 of 4 (70 Views)
Re: Link parameters in iMate
12-04-2012 03:00 PM in reply to: j.vanderheijden
Hi Jos,
Maybe that is the issue which related to the iMate. I will double check with the Inventor QA and update on you later.
Sorry for the inconvenience that will take to you.
-Xuesong
j.vanderheijden
Message 3 of 4 (65 Views)
12-04-2012 11:08 PM in reply to: XuesongBai
Thanks for your concern.
I have now also another solution.
I now use work planes with an offset and the offset I have a parameter linked to the paint thickness to control.
On the work planes I place  now the iMates.
Mvg Jos
Employee
XuesongBai
Message 4 of 4 (59 Views)
12-05-2012 05:58 AM in reply to: j.vanderheijden
Hi Jos,
It is pretty cool. Anyway, I will figure it out.
-Xuesong
