Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
How to update computed parameter
3 REPLIES 3
Logos_Atum
387 Views, 3 Replies
Hello there,
I modelled a tray and now I want it to display the outer
dimensions but accept input for the inner dimensions.
I use iLogic to compute the outer dimensions, it works.
outerlength=Parameter("lengthload")+96
outerwidth=Parameter("widthload")+4
There is but one problem. As soon as I publish the asset
and change the inner dimension the value of outerlength
is not updated. Which code do i need to add to force an
update of the parameters value?
Any help is greatly appreciated!
P.S.: Has been added with no effect, I think I got it wrong
Parameter.UpdateAfterChange=True
Kind regards
Daniel
Dogs aren´t flammable.
3 REPLIES 3
in reply to: Logos_Atum
Heey Daniel,
Maybe this is possible with the line: Parameter.UpdateAfterChange = True. You can find it in the Edit rule screen,  on the left side under Document.
Place this at the top the top of your rule. Create an Event Trigger, this option is located below the iLogic Browser. Doubleclick on Any Model Parameter Change and add your rule there. The rule will be triggerd when you change a parameter and will be updated by the added line.
Hope this works for you!
Robbert
Logos_Atum
Hi Robbert,
thanks! That worked quite fine 🙂
Hope you´ve been helped with
your asset issues too.
See you
Daniel
Glad it helped 🙂 Asset issue isnt solved yet unfortunately.
