Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
how to pattern a color
4 REPLIES 4
nstalker
460 Views, 4 Replies
How do you pattern a color?  I'm altering this existing Creform Placon Conveyor Factory Asset.  When I pattern the roller lanes the color does not come through on some of the lanes.
4 REPLIES 4
yizhou.cao
in reply to: nstalker
Unfortrunately, feature colors are not copied when you pattern. I'll report the issue. To work around this, you can create a pattern of the rollers and set the pattern to the desired color, and do the same for the side rails.
Yizhou C
Autodesk Factory Design team
Logos_Atum
Hello there,
this is not entirely right I guess... no offence...
given this is a single volume body, you can pattern the assigned colours.
Simply change the mode of the pattern (also works with mirroring ect.)
to volume body and the colours are copied alongside the geometry. This
is very handy when you consider dividing your objects into multiple parts.
I´ve attached some screenshots depicting how it works. It´s not that easy
to split up bodys lateron, but when you´re designing a new part, it abso-
lutely makes sense to consider the extra time you would be spending as
you assign new appearances.
Hope this helps
Kind regards
Daniel
Dogs aren´t flammable.
nstalker
in reply to: Logos_Atum
This is very helpful!  Thank you Daniel!
Logos_Atum
Hello there,
glad it helped. I meddled with the very same problem some year ago.
I never thought of this behaviour as a bug and got used to it 🙂
Kind regards
Daniel
