Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
How to debug a new chain asset
1 REPLY 1
patrick.fillion
362 Views, 1 Reply
I have create a chain asset with straigth and corner asset, that works fine. I try to create an other one using and when I use it as chain asset, I get the polyline in Autocad but nothing is comming accross in Inventor. I can insert a 2d block and that will transfert, I can insert from the 3D. The connectors works. So, in that case, How do we do debugging as the chain creator is web base???
Tags (4)
1 REPLY 1
Can you share you straight and corner assets with me and also share your .assetchaining file? You can send to me by xuesong.bai@autodesk.com
-Xuesong
Please mark as a solution if somehow I got it right.
