Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Message 1 of 21
1913 Views, 20 Replies
FDS - API
Hello all,
Is there any way to build asset (using Asset Bulider) thru API?????? Using built in VBA in Inventor, is there is any chance of building factory assets, defining landing surface, insertion point , adding descriptors etc??
any help would be much appriciated..
20 REPLIES 20
Message 2 of 21
XuesongBai
Hi there, Currently, the APIs of FDS is not avaiable now. Thanks, -Xuesong
Please mark as a solution if somehow I got it right.
Message 3 of 21
in reply to: XuesongBai
Thanks mate, looks like FDS API is there in FDS 2015. Right??
Message 4 of 21
All,
Is the API available now for FDS 2016?  If you have any questions, please do not hesitate to contact me.  Hope all is well and have a most blessed day!
Peace,
Pete
Just a guy on a couch...
Please give a kudos if helpful and mark as a solution if somehow I got it right.
Message 5 of 21
Hi Pete, The 2016 API exposes the ability to enumerate asset instances in the layout and manipulate their instance properties. What type of API-driven workflow were you thinking about? Oleg
Message 6 of 21
Thanks for the update Oleg!  I don't have any particular workflow in mind, but a client of mine was asking.  Is there a way to get a list of the new objects and operations that are available via API?
Message 7 of 21
No formal documentation yet - work in progress Oleg
Message 8 of 21
LukeDavenport
in reply to: olegd.prod
Hi Oleg,
Any update on this please?
Luke
Message 9 of 21
olegd.prod
in reply to: LukeDavenport
Hi Luke,
If you are asking about formal documentation - no, nothing yet.
Oleg
Message 10 of 21
LukeDavenport
Hi Oleg,
How about informal?
Luke
Message 11 of 21
olegd.prod
Message 12 of 21
wezpb
Is there an API for factory design utilities (within Inventor) yet? Specifically i would like access to the assigned layers so we can automate layering within the drawing to match the layers of those already assigned to the assets.
Thanks.
Message 13 of 21
olegd.prod
in reply to: wezpb
No changes here.
I am curious about your scenario - if you place an asset on a layer in Inventor, we will place it on that layer in ACAD. How is that different than what you are trying to do?
Oleg
Message 14 of 21
olegd.prod
in reply to: wezpb
No changes here.
Oleg
Message 15 of 21
wezpb
I want the asset to be on the same layer on an inventor drawing, not acad
Message 16 of 21
olegd.prod
in reply to: wezpb
So first I have to confess my ignorance about layer behavior on Inventor drawings ... 😞
But with that said, I am not sure why you would need Factory API here... If Inventor API supports designating part/assembly-to-layer mappings, then this is something you should be able to do for Factory assets (they are just parts/assemblies in Inventor).
Or am I missing your point?
Message 17 of 21
wezpb
In Inventor Factory you assign a layer to the asset within the Layout Model. Are you saying this Layer information is available in the API/iLogic? do you have an example?
Message 18 of 21
petestrycharske
in reply to: wezpb
wezpb,
Good morning!  It's been a while since I've used this code, but if I remember correctly all you need to do is create each of the separate features as a new solid body and then this will create new layers and place the objects on those layers in an Inventor drawing.  I think you can also create the layers in the drawing ahead of time and then the objects will inherit those layer properties (color, etc.).  Let me know if you have any questions.  Hope this helps and have a most blessed day!
Peace,
Pete
oDrawDoc = ThisDrawing.Document
oModelDoc = ThisDrawing.ModelDocument
Dim oLayers As LayersEnumerator
oLayers = oDrawDoc.StylesManager.Layers
Dim transObjs As TransientObjects
transObjs = ThisApplication.TransientObjects
For Each oSheet As Sheet In oDrawDoc.Sheets
    For Each oView As DrawingView In oSheet.DrawingViews
        Dim oPartCompDef As ComponentDefinition = oModelDoc.ComponentDefinition
        'MessageBox.Show(oPartCompDef.SurfaceBodies.Count)
        For Each oSufaceBody As SurfaceBody In oPartCompDef.SurfaceBodies
            'MessageBox.Show(oSufaceBody.Name)
            Dim LayerName As Layer
            LayerName = oLayers.item(oSufaceBody.Name)
            Dim oDrawCurves As drawingCurvesEnumerator
            oDrawCurves = oView.DrawingCurves(oSufaceBody)
            Dim oObjColl As ObjectCollection
            oObjColl = transObjs.CreateObjectCollection()
            For Each oDrawCurve As DrawingCurve In oDrawCurves
                 Dim segment As DrawingCurveSegment
                For Each segment In oDrawCurve.Segments
                    oObjColl.Add(segment)
                Next
            Next
            Call oView.Parent.ChangeLayer(oObjColl, LayerName)
        Next
    Next
Next
Message 19 of 21
wezpb
in reply to: petestrycharske
Thanks that will certain help for the non-factory models. Will have to wait and see if Autodesk ever release API for factory then.
Message 20 of 21
petestrycharske
in reply to: wezpb
wezpb,
This is a rule that is used on the drawing.  It should work for factory assets as well.  In fact, it was a factory user who asked me to look into this.  You will only have to make the different components of an asset as different solids to get this to work.  Hope this helps and have a most blessed day!
Peace,
Pete
