Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
FDS 2014 Premium - AUTOCAD SP1 WILL NOT INSTALL
5 REPLIES 5
BStrothcamp
555 Views, 5 Replies
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22264351&linkID=15639656
Says my product cannot be found if I run it stand alone. If I try installing through AutoCAD Architecture is starts installing then backs out with a generic error.
Is this messed up or am I doing something wrong?
5 REPLIES 5
BStrothcamp
in reply to: BStrothcamp
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22420526&linkID=9240658
Also tried that one which is specific to Architecture with same result...
A problem prevented the Service Pack from being installed. Error code:1603
Photonyxx
I am seeing the same issue. The service pack will not initialize even though I have the correct product.
XuesongBai
hi there,
AutoCAD is separate installed. As default, AutoCAD will not be installed with FDS.You need to check the download of the AutoCAD installer in the panel when installing the FDS.
-Xuesong
Please mark as a solution if somehow I got it right.
eljoseppo
in reply to: XuesongBai
I have similar problem. Maybe not related with Autocad but with FACTORY SP1.
I still have notice displaing forceing me to install the SP1 althought I did it before.
  Since the forum has changed I did not have time to get familiar with new layout. I still don't know how to search in Factory forum, that's why I'm writing here. Sorry.
guosu
in reply to: eljoseppo
This is a known issue that communicate center still tells you "Factory Design Utilities 2014 Update available" although you have installed it successfully. Please ignore it. You could check whether FDU SP1 has been installed from control panel. Thanks, Sucy
