Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Failed to create the drawing base view
4 REPLIES 4
nstalker
666 Views, 4 Replies
Trying to make a simple asset.  I drew it in ACAD and exported it to ACIS/SAT.  It imported fine into Inventor.  I went into Asset Builder, selected a landing surface and then went to publish it and I got this error (see attached).  I've attached the SAT file itself because it's incredible that it can't generate a 2d plan view of this very simple part.
4 REPLIES 4
nstalker
in reply to: nstalker
OK I tried a STEP file and it worked.  Any idea why Inventor could read the ACIS file but not be able to generate the 2d drawing in the publishing step?
bobvdd
I works for me with SAT too.
Bob
Bob Van der Donck
Principal UX designer DMG group
nstalker
in reply to: bobvdd
thanks for trying Bob.  I wonder why it wouldn't work for me.
XuesongBai
It also works for me.
It sounds like you will fail to create the base view in Inventor drawing.
Perpaps, we need to ask for Inventor team looking at the issue.
-Xuesong
Please mark as a solution if somehow I got it right.
