Hi !
When I install the Factory Design Utilities update 1 (http://knowledge.autodesk.com/support/factory-design-suite/downloads/caas/downloads/content/autodesk... have an error with the navisworks hotfix about point cloud.
The error says "Navisworks 2015 dwg Point Cloud hotfix (NW-47812) : An error occured while installing this product. For more information view the installation log file.
I think it's because I already installed the Navisworks SP1 but I'd like to be sure because it's not written properly in the documentations (there's nowhere a line like "this hotfix is included in navisworks SP1" or something similar).
Reading the log gives me the confirmation that it's because the navisworks SP1 i already installed : Navisworks Factory will crash after installed Navisworks SP1. (FDS19101)
I hope it can be usefull to someone 😉
(at the beginning of writting this message I was not 100% sure it was the cause but I prefere to keep this message for other people encountering the same issue)
Solved by aguitton116. Go to Solution.
