Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Factory Design suite tools
6 REPLIES 6
Wmcd17
782 Views, 6 Replies
I recently installed the AutoDesk factory design suite and I can't find or access any of the factory tools. I've posted a screen shot below to help explain my problem.
6 REPLIES 6
jeff.pek
in reply to: Wmcd17
Seems like there's a problem with loading the plugin -- despite the UI being put in place.
Do you see anything in the command log history that might indicate a problem?
 Jeff
Wmcd17
in reply to: jeff.pek
I didn't notice anything, here's a screen of my command history.forum image for autocad 2.jpg
jeff.pek
in reply to: Wmcd17
If you just type "FACT" into the command line, do you see any commands like "FACT_STARTUP" showing up in the drop-list?
If not, this would indicate that the plugin isn't loaded.
Which AutoCAD are you running? Is this Architecture? Mechanical?
Which version?
  Jeff
Wmcd17
I typed FACT and there was a list of options including FACT_ABOUT, FACT_FACTORYBROWSER, etc. Heres another screen shot, but I think you're probably right about the plugin not being loaded. Do you have any fix ideas for that sort of problem?
I'm currently running normal AutoCAD 2012, not mechanical or architecture. I have tried to access the factory tools in those two versions also, but no luck.
jeff.pek
in reply to: Wmcd17
Thanks for the screenshots.
The Factory plugin will not load in Vanilla AutoCAd. It's intended for use only in AutoCAD Architecture or AutoCAD Mechanical.
Do you see exactly the same behavior when you run one of those flavors?
Can you check what files/folders you have in C:\Program Files\Autodesk\ApplicationPlugins?
Just want to make sure things seem to be installed properly.
Here, you should see a folder named FactApplication_R (something; don't recall the exact numbering for 2012).
This will have a Packagecontents.xml file in it, along with additional subdirectories.
How many files are in this overall directory structure? You can get Properties on the "FactApplication*" directory to get this.
  Jeff
Wmcd17
I think that must have been the problem, I just found a setup app in the folder you mentioned, ran it, and everything seems to be working now. The only oddity is that my boss seems to be able to access factory in autocad vanilla. In any case, thank you for the help, and I think I should be all set now.
Will
