Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Factory Design and Acad
3 REPLIES 3
j.vanderheijden
569 Views, 3 Replies
I have instaled Factory Design and when i want to use Acad it opens Acad Mechanical.
I don't want to use Mechanical.
Can i open Acad instead of Mechanical?
Mvg Jos
Your drawings are only as good as the symbols that complete them...
3 REPLIES 3
Currently, the Factory design is not supporting AutoCAD.It works both in AutoCAD Mechanical and Architecture now.
So,thank you very much for the  we are considering this functionality as candidates for a future release of Factory Design Suite.
-Xuesong
Please mark as a solution if somehow I got it right.
I've discovered Acad works within Factory Design.
You can start Acad by going to Start, then Programs, then Autodesk, then AutoCAD Mechanical, and you'll find a link that starts Acad.
Drawings made ​​with this Acad can be  loaded in Factory Design.
I thought you should know this.
Mvg Jos
Thank you very much for following up the info.
-Xuesong
