I have instaled Factory Design and when i want to use Acad it opens Acad Mechanical.
I don't want to use Mechanical.
Can i open Acad instead of Mechanical?
Solved by XuesongBai. Go to Solution.
Currently, the Factory design is not supporting AutoCAD.It works both in AutoCAD Mechanical and Architecture now.
So,thank you very much for the we are considering this functionality as candidates for a future release of Factory Design Suite.
-Xuesong
I've discovered Acad works within Factory Design.
You can start Acad by going to Start, then Programs, then Autodesk, then AutoCAD Mechanical, and you'll find a link that starts Acad.
Drawings made with this Acad can be loaded in Factory Design.
I thought you should know this.
Thank you very much for following up the info.
-Xuesong
