Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Error message when mirroring assets
4 REPLIES 4
Logos_Atum
400 Views, 4 Replies
Hello there,
recently FDS started to display error messages when mirroring
assets. It seems like some parameters are´nt exported properly
anymore. As we used the assets in other assemblies without
getting error messages we´re wondering what went wrong. The
errors don´t have any effect on eihter appearance and performan-
ce and the asset properties can still be changed, but it would be
good to know why this happens and what we need to change or
avoid, to stop this from happening.
I´ve attached a sscreenshot of the design doctor output to clarify
Kind regards
Daniel
Dogs aren´t flammable.
4 REPLIES 4
XuesongBai
in reply to: Logos_Atum
Hi Daniel,
The reason is the original asset which is derived by mirrored asset cannot be updated automitically. I think that is an issue in FDS, we need to resovle it in the next release.You can manually update the derived asset.
However, I have question about the Mirror. Why not check the Reuse the selected objects option when you do mirror?
-Xuesong
Please mark as a solution if somehow I got it right.
Logos_Atum
in reply to: XuesongBai
Hello Xuesong,
oh okay. We will see to that. As i said before it´s merely
cosmetically. Reusing the object somehow changes it´s
orientation, therefore we can´t make use of it in this case.
Kind regards
Daniel
XuesongBai
Hi Daniel,
Could you please share the asset with me by my email  and please show me the how it change orientation? I will look closed at the issue in my machine and check if I can fix it.
-Xuesong
Logos_Atum
Hello Xuesong,
thanks for the offer. I will send you the
data as soon as I can. We´re quite busy
at the moment.
Have a nice day
Daniel
