Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Displaying ACAD Overlay in .iam Model in the .idw for that model
3 REPLIES 3
399 Views, 3 Replies
How do I display an externally referenced AutoCAD DWG Overlay for a factory assembly model in the .idw for that model? I am using an externally referenced AutoCAD DWG for all the factory existing geometry which is typically all 2D. The iam will update when the DWG is updated. Now I just need it to be displayed and also updateable in the idw.
3 REPLIES 3
Logos_Atum
Did you try creating a draft view and using the Insert AutoCAD drawing?
If not I think you might need a dummy object onto which you need to insert the DWG to.
You also could convert the DWG to Mass elements and use an IGES export. Both
solutions thus, won´t be updating if you change the DWG file.
Kind regards
Daniel
Dogs aren´t flammable.
I have created an .idw displaying a plan view of the model along with creating a sketch with the AutoCAD drawing inserted into it. I changed the options for DWG Insertion points to be the model origin as well as set the origin in the AutoCAD 2D dwg to the same point for a smooth easy import.
in reply to: Logos_Atum
I am not familiar with converting to mass elements.
