Is someone aware that the Inventor's contact solver is not working when making a contact set of Factory Assets. No collision is detected!
Did the test with the same files but then imported in a regular assembly as regular parts, and that works fine.
Any suggestion to make this work in a Factory layout?
Solved by XuesongBai. Go to Solution.
Hi Peter,
The contact solver is conflict with Snap fuctionality in Factory layout. So you can disable the "Snap" functionality in Factory Options.
-Xuesong
