So I closed my model last night and this wasn't the case. This morning I opened my model and where my connectors are showing triads as well as the work planes being turned on. I can go turn off the work planes but I can't figure out how to get the triads to go away. Please help!
Hi there,
Do you have any special operation on the asset?
Could you please share the model with me?
I will only use it in Autodesk internally.
My email is Xuesong.bai@autodesk.com.
-Xuesong
Hi Will,
We can reproduce the issue and we are investigating the solution now.
The reason is that you change the View as Master obliviously when you open the layout.
As a workaround, you can change the view as Default.
-Xuesong
That work around worked for the planes but not for the XYZ tridents. Suggestions?
-Will
Hi Will,
That is working for me with your assets shared with me after changing the View as "Default".
If not working for you, could you please try to hide all objects by unchecking all workfeatures in View Tab>-Object Visibility panel.
-Xuesong
What I did to get rid of them was change the design view representation in the pop up you get by right clicking the part/assembly and selecting representaion then setting the Design View as associative and set to default.
Has there been any development on the cause of this? It makes it really hard for me to use factory assets modeled as assemblies.
