Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Connector should be a point of the edge, can't use user defined point?
3 REPLIES 3
352 Views, 3 Replies
Dear All,
We are testing the connector definition. we meet problem that the conveyor's height can't automatically change if the connector isn't the a point of the edge.
Please get the attachment. for ShockConveyor.ipt, we defined 2 connector of the right side, one is a midpoint of a edge(connector4), the other is intersect point of three plane(connector5).  the connector4 work correctly but failed with connector5.
What wrong with it?it's the limited of the connector point?
My Best Regards,
Rick
3 REPLIES 3
XuesongBai
Hi Rick,
Yes,  that is the limitation. The connector 5 only propagate the parameter "RightHeight'. Currently, the connector class didn't allow defining the expresion, say "RightHeight+300mm".
Spoiler
-Xuesong
Please mark as a solution if somehow I got it right.
XuesongBai
Hi Rick,
I am writing a ilogic code to control the RightHeight based on which Connector is consumed.
If (RightHeight <> iProperties.Value("Custom", "RightHeight_backup")) Then
 RightHeight1= RightHeight+300 mm
  ParaChange = 0
Else If (RightHeight1 <> iProperties.Value("Custom", "RightHeight1_backup")) Then
 RightHeight = RightHeight1 -300 mm
End If
iProperties.Value("Custom", "RightHeight_backup") = RightHeight
iProperties.Value("Custom", "RightHeight1_backup") = RightHeight1
Also,I added new parameter RightHeight1 and set as key (must be set as key) in model and update the connector class .
Thanks, Xuesong, It's work very well!
