I have made an assembly with one part that has all the user parameters, wich is linked to all the other parts. So if I change something in the part with the user parameters, the other ones will go along with it (Skeletal Modeling). I have linked the parameters to the assembly too.
Now I want to create an asset of this assembly and make a custum Connector Class Propertie for this assembly so that a few parameters of connected assembly's will scale along if I change the first one.
The problem is that when I have created a ConnectorClass it wont recognize the parameters. I think that the problem lies with the fact that the parameters he needs to find lie in a part within the assembly, and not in the assembly itself (although the parameters are linked to the assembly).
Does anyone know how to get this working? So that the ConnectorClass for the assembly can find the parameters in a part within the assembly? There is very litle information to be found on the internet about ConnectorClasses. I have attached the files.
I hope that you guys understand what I mean 🙂 Thanks in advance,
Robbert
Okey, I have found out how it works myself 🙂 Used iLogic to overwrite the part parameters with the assembly parameters. FDS was able to find the assembly parameters and now it works.
That surely will prove usefull I think.
kind regards
Daniel
