Autodesk Factory Design Suite General Discussion
Distinguished Contributor
nstalker
Message 1 of 8 (214 Views)
Connection Orientation Failure
214 Views, 7 Replies
11-13-2012 08:08 AM
I am having problems getting two user assets to connect properly.  It seems like I have tried every possible orientation of  X,Y and Z to no avail.  These are parametric guardrails similar to the guardrail in the system assets.  I tried to even make the connection points in the same orientation as the system asset but it does not work.  The system assets attach to each other fine so I don't know what I'm doing wrong.
Employee
ted.saufley
Message 2 of 8 (204 Views)
Re: Connection Orientation Failure
11-13-2012 09:46 AM in reply to: nstalker
nstalker,
Is this what you're trying to achieve? (See attached.) I was unable to replicate your problem.
-Ted
Ted Saufley
Principal Content Developer
DLS Manufacturing Engineering
nstalker
Message 3 of 8 (199 Views)
11-13-2012 09:48 AM in reply to: ted.saufley
Yes but mine will not connect that way. I'm not sure why.
Employee
ted.saufley
Message 4 of 8 (197 Views)
11-13-2012 11:25 AM in reply to: nstalker
nstalker,
Please check your Snap settings in the Factory Options dialog box. (See the attached image.)
-Ted
Ted Saufley
nstalker
Message 5 of 8 (193 Views)
11-13-2012 11:37 AM in reply to: ted.saufley
Ted,
Thank you for your response.  How do I get to the Factory Options dialog box?
Employee
ted.saufley
Message 6 of 8 (189 Views)
11-13-2012 11:44 AM in reply to: nstalker
If no layout is currently open, click Get Started tab > Factory Launch panel > Factory Options.
If you do have a layout currently open, then click Factory tab > Options panel > Factory Options.
Ted Saufley
nstalker
Message 7 of 8 (187 Views)
11-13-2012 11:45 AM in reply to: nstalker
Thanks Ted!  I adjusted my settings to be like yours and I still have this problem (see attached)
Employee
XuesongBai
Message 8 of 8 (174 Views)
11-13-2012 06:07 PM in reply to: nstalker
The problem is that the direction of X , Z axis  are not correct when you change the asset variant as 8ft_1_Post. Please make sure the +Z direction is vertical to the landing surface, whilst +X direction is along with the way of chain. Please give a try to the asset I edited as attached.
-Xuesong
