Autodesk Factory Design Suite General Discussion
Active Contributor y-p
Active Contributor
y-p
Message 1 of 4 (377 Views)
Changing from single to network license without reinstalling + language question
377 Views, 3 Replies
04-05-2013 10:17 AM
I installed FDS PRM as single user only but I'm owning a network license (ok, I should have known :smileywink: ).
Is it possible to change the type of license after installation or do I have to reinstall it?
That wouldn't be that great as this takes ages and reinstalling plugins, too..
Additionally I'd like to know if I can use the english version with my german license.
I was told so by my distributor, I just want to be safe before installing the wrong version.
Thanks in advance,
Niko
Employee
XuesongBai
Message 2 of 4 (361 Views)
Re: Changing from single to network license without reinstalling + language ques
04-06-2013 06:20 PM in reply to: y-p
Hello Niko,
Yes, you can change the license type without reinstall.
For Autocad, you can change the value to switch between standalone and network.
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R19.0\ACAD-B004\AdLM]
"Type"=dword:00000002
1: Network
2: Standalone
3: Multi-seat Standalone
For Inventor, you need to change the several key to switch between standalone and network.
For network:
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Inventor
RegistryVersion17.0\ADLM         Type = 1
RegistryVersion17.0                        LicenseMode = 1
RegistryVersion17.0                        LicenseType = Network License
RegistryVersion17.0                        StandaloneNetworkType = 3
For Standalone:
RegistryVersion17.0\ADLM         Type = 2
RegistryVersion17.0                        LicenseMode = 2
RegistryVersion17.0                        LicenseType = Stand-Alone License
RegistryVersion17.0                        StandaloneNetworkType = 1
-Xuesong
Active Contributor
y-p
Message 3 of 4 (350 Views)
04-07-2013 07:35 AM in reply to: XuesongBai
Hi Xuesong,
thanks for your effort.
As I had many components of FDS PRM installed I probably would have had to change the registry in all cases.
Anyway I uninstalled the whole suite and reinstalled only 3DS now as this is my main component.
Now I'm getting the -15.570 error about obtaining license..
I followed Travis' help about the IP4 disabling from here: http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982... but had no luck. I changed the hosts file and deactived IP6 as well..
So I'm a bit lost right now- may it be related to the fact that I have the german license as mentioned above but installed the english version?
Since this may be the case I'll leave it in this thread for now- but probably it would be better to start a new thread soon as the title does not represent the actual question anymore...
PS: I'm on a Win 8 system btw.
Active Contributor
y-p
Message 4 of 4 (343 Views)
04-07-2013 08:06 AM in reply to: y-p
I'll post another question in the licensing section as this is not FDS related anymore.
Please close this thread.
