Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Changing from single to network license without reinstalling + language question
3 REPLIES 3
y-p
2016 Views, 3 Replies
I installed FDS PRM as single user only but I'm owning a network license (ok, I should have known 😉 ).
Is it possible to change the type of license after installation or do I have to reinstall it?
That wouldn't be that great as this takes ages and reinstalling plugins, too..
Additionally I'd like to know if I can use the english version with my german license.
I was told so by my distributor, I just want to be safe before installing the wrong version.
Thanks in advance,
Niko
3 REPLIES 3
XuesongBai
in reply to: y-p
Hello Niko,
Yes, you can change the license type without reinstall.
For Autocad, you can change the value to switch between standalone and network.
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R19.0\ACAD-B004\AdLM]
"Type"=dword:00000002
1: Network
2: Standalone
3: Multi-seat Standalone
For Inventor, you need to change the several key to switch between standalone and network.
For network:
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Inventor
RegistryVersion17.0\ADLM         Type = 1
RegistryVersion17.0                        LicenseMode = 1
RegistryVersion17.0                        LicenseType = Network License
RegistryVersion17.0                        StandaloneNetworkType = 3
For Standalone:
RegistryVersion17.0\ADLM         Type = 2
RegistryVersion17.0                        LicenseMode = 2
RegistryVersion17.0                        LicenseType = Stand-Alone License
RegistryVersion17.0                        StandaloneNetworkType = 1
-Xuesong
Please mark as a solution if somehow I got it right.
y-p
in reply to: XuesongBai
Hi Xuesong,
thanks for your effort.
As I had many components of FDS PRM installed I probably would have had to change the registry in all cases.
Anyway I uninstalled the whole suite and reinstalled only 3DS now as this is my main component.
Now I'm getting the -15.570 error about obtaining license..
I followed Travis' help about the IP4 disabling from here: http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982... but had no luck. I changed the hosts file and deactived IP6 as well..
So I'm a bit lost right now- may it be related to the fact that I have the german license as mentioned above but installed the english version?
Since this may be the case I'll leave it in this thread for now- but probably it would be better to start a new thread soon as the title does not represent the actual question anymore...
PS: I'm on a Win 8 system btw.
y-p
in reply to: y-p
I'll post another question in the licensing section as this is not FDS related anymore.
Please close this thread.
