I want to make Chain Assets but i only want to use straight assets.
Is it possible to exclude the corner asset and only use the straight asset.
I don't want to go around the corner with the chain asset.
Solved by XuesongBai. Go to Solution.
Hi Jos,
Currently you cannot skip the step for the corner asset. As workaround, you can select straingth asset and arbitrarily fill in some parameters.
-Xuesong
