Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Cannot change asset properties in AcadM, only in 3D Inventor
1 REPLY 1
patrick.fillion
357 Views, 1 Reply
When I insert assets in the Autocad, my asset property is open but empty. Even when I select an asset on the screen. The only way I found the change values is in Inventor, but really, I would like to be able to change it in Autocad. This is with r2013. Does anyone had this problem?
1 REPLY 1
The only way that you willl be changing the parameter values for asset in AutoCAD is to use variants.
Please refer to anther same topic http://forums.autodesk.com/t5/Autodesk-Factory-Design-Suite/Changing-Asset-Properties-in-ACADA-or-AC....
-Xuesong
Please mark as a solution if somehow I got it right.
