Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Autocad Architecture in FDS
3 REPLIES 3
jostroopers
914 Views, 3 Replies
Is it possible to draw walls in Autocad Architecture and sync them to Factory Design and make shaded solids and constrain to the walls with Inventor parts.
Mvg Jos
Youre drawings are as good as the symbols that compleet them.....
3 REPLIES 3
Logos_Atum
in reply to: jostroopers
Hello there,
we´re using the following workflow:
1. Drawing onto the 2D with AcadArchitecture elements
2. Convert Architecture elements to volume bodies and save DWG
3. Import Volume DWG to inventor and treat them as ordinary Inventor geometry in there
Hope this helps 🙂
Also I´ve attached images of the functions, sadly in German, yet the symbols should look the same 🙂
Dogs aren´t flammable.
jostroopers
in reply to: Logos_Atum
Danke für die Erklärung, es funktioniert.Smiley Very Happy
Thanks for the workflow, its working.
Mvg Jos
Logos_Atum
Glad it does
kind regards
Daniel
