Can anyone make a general estimate for the amount of time it takes to create one asset from point cloud data? Let's assume that the user if an average user of Factory Design Suite and their software and hardware are up to date. Just curious to know if it's minutes, hours, or more...
We are scanning a huge plant with hundreds of assets and there is an interest to use the point cloud data to create the unique assets.
Hi there,
If my understanding is correct, you want to extract the unique point cloud asset from the scan plant point clouds.
You can create the scan region of each asset and export it as RCS format point cloud in AutoCAD ReCap and then attach it in Inventor.
By the way, please install the sevice pack 1 in AutoCAD Recap for export the scan region to RCS format point cloud.
I think it will be taking seconds for creating one unique point cloud asset.
-Xuesong
Hi Chris,
I don't think handling the point cloud asset in Inventor will take much effort. Becuase most cleanup work have been done in AutoCAD ReCap.
The attached is the workflow I created in Factory Inventor 2013 for your reference.
-Xuesong
