Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Array in Factory
3 REPLIES 3
Logos_Atum
268 Views, 3 Replies
Array in Factory
Hello there,
I did an array of a object in factory. I noticed something curious.
When i do two instances only it just arrays as it should. When
doing more than one instance, planes originally hidden are tur-
ned visible again. That´s kind of awkward, especially as you can´t
save the state to the object in use.
Is this normal bahaviour or do i need to worry something´s wrong?
Kind regards
Daniel
Dogs aren´t flammable.
3 REPLIES 3
yizhou.cao
in reply to: Logos_Atum
I can't reproduce the issue. Can you clarify your steps? Did you use the Pattern command to create an array? Is the workplane in the layout or in the component you patterned?
Yizhou
Yizhou C
Autodesk Factory Design team
Logos_Atum
in reply to: yizhou.cao
Hello there,
Yes I did use the pattern command to create the array.
The workplane is in the component I patterned, right.
Hope this will help you
Kind regards
Daniel
Logos_Atum
Any progress so far already?
