Execute Script
Execute Script
Would be nice that after you use "EXECUTESCRIPT" that it remembers where your scripts are stored on PC.
It defaults to Desktop.
6 Comments
Mine doesn't!! HAHA!! 😉
cadbob
wtf 🙂
cadbob
Mine is now with SP1 Smiley Wink
tim-bot
for the .net savy
<CommandMethod("ABCD", "CustomExecuteScript", CommandFlags.Modal)>
    Public Sub CustomExecuteScript()
        Using oDlg As New System.Windows.Forms.OpenFileDialog With {
            .AddExtension = True,
            .AutoUpgradeEnabled = True,
            .CheckFileExists = True,
            .DefaultExt = "cod",
            .DereferenceLinks = True,
            .Filter = "CADmep Script Code (*.cod)|*.cod",
            .Multiselect = False,
            .Title = "Execute Script"}
            If oDlg.ShowDialog = Forms.DialogResult.OK Then
                Doc.SendStringToExecute("(Progn (Command ""TakeOff"")(ExecuteScript """ & oDlg.FileName.Replace("\", "/") & """)(Princ)) ", True, False, False)
            End If
        End Using
    End Sub
andy.robins
andy.robins
Executescript command now uses and remembers the SCRIPT folder defined in MAP.INI instead of the desktop.
